  » Forum » Turntables (english only - please!) » 12x0 - Modding » under platter LED how to
DJ-NITRO-UK
# 18.09.2017 - 00:55:33
Hi there,
I have purchased a cheap LED strip kit from ebay which you can change colour using a remote control and powers directly to a UK power source.
here is a link to what I purchased:
http://www.ebay.co.uk/itm/Waterproo...IT&_trksid=p2060353.m2749.l2649
I would like to power the LED's internally using the Technics power supply.
Please can somebody explain to me what I need to do in order to complete this.
I am from the UK :)
# 18.09.2017 - 14:15:58
first of all there is not enough space between the cover and the platter, so your LED Stripe wont fit under the platter without destroying the cover.
and then there is a power consumption problem, the internal power supply is to weak to supply both, your deck and the LED stripe, youll need the aditional power supply, doesent matter if it is the one delivered with the stripe or another one that suits your needs... but i dont think it will go well without a 2nd power supply.
greetings, Fabian
DJ-NITRO-UK
# 22.09.2017 - 00:36:36
thank you for your reply, would I be able to mount this inside the turntable directly from the internal power and wire the LED's to it?
http://www.ebay.co.uk/itm/PSU-DC12V...IT&_trksid=p2060353.m2749.l2649
I can mount the LED's no problem inside the deck but would be great if I can find a way of internally powering them
# 22.09.2017 - 10:15:34
You could, but ill suggest strictly to not do this.
Youre playing with 230V inside a Protection-Class 2 Device with a metal case.
If you do a mistake or get a lose wire after a time > risk of death.
DJ-NITRO-UK
# 22.09.2017 - 11:54:51
Okay so what is the best way of internally powering any LED's for under the platter?
# 22.09.2017 - 14:27:04
Best bet (imo, did it some times. there is maybe a better way) is:
Buy some LEDs, drill 3mm Holes into the black Cover under the Plate, connect them with wires and some some kind of glue and then connet it to the mainboard.
But you need to calculate LED/Preresistor to get 20V voltage-fall total.
then connect to Ground (for example lower left Mainboard-Screw and +20V (needlelamp).
But im not sure if the Power from the orinigal transformator is high enough. i use other Transformator because i mostly convert Japanese Turntables for use with 230V supply
Zuletzt modifiziert von Pyneos am 22.09.2017 - 14:28:55
DJ-NITRO-UK
# 21.10.2017 - 01:06:18
what if I installed this 6w transformer onto the internal power supply:
http://www.ebay.co.uk/itm/UK-STOCK-...h=item43ce85833f:g:mN8AAOSw8HBZJS1m
This looks exactly the same as the halo under platter kits which are sold within the UK
# 22.10.2017 - 10:30:35
then you need to connect this transformer parallel to main supply and embed an additional fuse for the primary transformator side.
And By the way... this transformator price is not realy thrustable. i would get a stomach if u use this extremely cheap china stuff.. cant belive that its rly safe
Zuletzt modifiziert von Pyneos am 22.10.2017 - 10:32:25
